I had some rust and a pin hole in my tank from letting the bike sit. I have used JB Weld to close the hole and want to coat the inside of the tank with Red-Kote. If I remove the petcock and fuel screen from the fuel tank, and I assume remove the gas door assembly, I believe that I am left with the vent lines inside the tank. Do I need to worry about clogging them with the Red-Kote when doing this? 完成后,将空气吹入管道是否可行? Thanks
